need help what is a 03 clk w?
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
A Friend Of Mine Has Bought A 2003 Clk 200 Kompressor Is His Model A W208 Or W209
100%Bitch
Norfolk 'n' good
It's a 209.
It's actually a C209 if it's a coupe and an A209m if it's a cabriolet.
horgantrevor
horgantrevor
www.flickr.com
Thanks Very Much I Hope All Well
Are The Any Common Faults That He Should Know About
100%Bitch
Norfolk 'n' good
Ah, now for that you'll have to wait for a technical person.
horgantrevor
horgantrevor
www.flickr.com
Its A Coupe
And Thanks Again Its Great Log In ,post And An Answer In Two Min
rf065
Grossbritannien
It would appear then that if you have a C209 or an A209, you have a model car. If you have a full size, real CLK, it is a W208 or w209.
Russ
BlackC55
South coast
C43
Watch out for knocking front suspension, broken rear springs. Is it a cab?
100%Bitch
Norfolk 'n' good
Russ
Russ, if that's what you believe then so be it. I think you'll find that it's an A or a C - and that's not just because it's a model.
BUT, I may be wrong, it's just that a lot of stuff on Wikipedia is garbage. Try googling A208/9 or C208/9. Don't forget you can have a C124(coupe), a W124 (saloon) and an S124 (estate). Oh yes, and the A124 (cabrio).
David Nock
South Yorks
CLK/2009/320CDI
If your friend's car is a Coupe and the VIN (in the corner of the screen) starts WDB 209, he has a W209.
Check out 'Valeo radiator problem' on this site's search facility.
horgantrevor
horgantrevor
www.flickr.com
thanks its is a w209
and is their any thing that we should look out for be sides rear springs ect
rf065
Grossbritannien
I'd major on the Valeo business!
Good advice, if one of the affected ones, it could be costly if you do not know about this problem. Worry about anything else later.
Russ
