New Battery Intall cause problems.
yellowspringuk
Surrey
C220 CDi MY2005
:confused:
Installed new battery today, everythin reset , no wipers, no fuel infomatio, key not opening doors and flasher not working, Help!!
Car W203 C180 year 2000
Are you sure that the battery is the correct polarity
Good call with that one Malcolm I would not of even thought of that.
Whats the weather like with you, are you enjoying the air con.
With this fault there is nothing else that could do this
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
the weathear is good, It was install by an Indi as favour, everything else work,
I will go abd doublle check the polarity just incase
Ouch, then if everything else works. ????? rear sam ? not for the wipers
wscheffer
Ohio, USA
www.scheffers.com
I am still playing with the Aircon... :eek:
I decided to have it vacked and charged before piecing her back together. She goes in tomorrow for this. I thought that even though I tightened the fittings to specks it will be easier to change or tighten something with it apart VS back together. :rolleyes:
Did find one problem in doing this though that the exterior light switch has to be plugged in in order for the climate controls and vacuum tree to work correctly. :D
If parts arrive soon ie Steering Column Cover, new blower motor, and all goes well. I hope to have her back together this weekend. :p
Thanks for asking though!
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
I've check the polarity, it is all ok . also there is a "display faulty visit workshop" message, i assume this is to do with the fuel gauge
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
But what do i need to check for the wiper?
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
I found another person with exatly the same problem as me , he was adivised to reacitivate the sam module using a star diagnostic. the guys has just repalced his battery just like i've done, i'm just want to know if this is a correct procedure before i go and waste my money
Thanks:confused:
Thanks:confused:
I mentioned this earlier and I will post back
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
Thanks malcom, I'm just at the panic stage!
one thing you could do is to disconnect the earth lead, leave for 10 mins and put it back, i will post back tonight
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
Couldn't do it as it started raining
OK you do have a front back up fuse box, that protects all of the SAM units the rear SAM N10/2 has a fuse in the relay module as does the N10/1 module.
You are going to have to check them all in the F32 box
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
  • #17
thanks malcolm, where or what is the F32 box? is it the fuse box by the drivers side?
Sorry I have moved on, it is a fuse module box, should be in the hand book, if you cant find it I will re check, its under the bonnet
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
  • #19
Just a quick update, I started the car this morning and everything is working OK, I did put the old battery back last night. Thanks for all your help Malcom. :D
yellowspringuk
yellowspringuk
Surrey
C220 CDi MY2005
  • #20
Sometimes it can something as simple as getting the correct ah as stated on your old battery.
I have this problem all last week, replaced battery with a brand new one and still same fault, return new battery to shop and changed old one still same problem, but it did reset it self over night and come back to normal
Then I did a search on battery and read what all the numbers means,
The following morning I phoned the dealer and eurocarparts for quote, dealer quoted £109(not sure if it include vat or not didn't ask, still cheap I think) and eurocarparts £91+vat = £107, dealer far away but eurocarparts can deliver,
So Bought Bosh silver 100ah with 800cca (cold cranking amps), ah (ampere hour/capacity) is more important when choosing battery.
Install new battery with correct ratings(same as on car previously), no error, display works first time, adjust ESP and I was on my way, car has been working since no problem, by the way the first new battery I got has 88ah and 680cca.
The reason I was getting the fuel gauge not working and doors, wiper, indicator, not working errors was that I was using incorrect ratings(not powerful enough) and my old battery was bad
Also repeatedly charging your battery with fast chargers damages it or weakens it further
