New Battery S5 A11 BOSCH AGM
Buck2003
2011 E220 CDI 2.1 diesel blue efficiency Auto Cabriolet
Hi all I've been searching for decent battery and wanted some advise.
I found this one if it fits size wise.
S5 A11 BOSCH AGM CAR BATTERY 12V 80AH TYPE 115 S5A11​
At Tanya's batteries (anyone used that company before?)
Its at a seemingly good price.
Any positive or negative comments about that battery or alternatively other good batteries would be appreciated, the image below was my battery voltage after just unlocking the car and plugging into obd scanner it drops to almost 0 on cranking
Big Cheese
WEST MIDLANDS
ML63 2007
I have just fitted a S5A13 to my S500, good quality battery.
Tanya is good and recommended
B
Buck2003
After much searching I ended up with the Varta silver 12v 800 80cc which is the same spec as the original mercedes battery, it was £189 locally or £169 at Tanya's batteries but also £8.99 postage...so for the sake of an extra £10, I got it there and then.
I was amazed when I discovered it still had the original Mercedes battery which would be around 14 years old now.
Should anyone be interested when the battery was tested on a better battery tester my old Merc battery showed 12.4 v standing charge but only 415 amps instead of the 800 it started with.
So hopefully this may resolve other issues. Also as I previously mentioned the battery doesn't need registration with the car.
Hope this helps
Rob
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
I have used Tayna several times always excellent service and rapid delivery. Varta Silver is my battery of choice and what came fitted to the car originally. I replaced several neighbours batteries when they all suffered from lack of use during Covid and needed replacing. As mentioned by others a battery charger/conditioner is almost a must now-a-days if you don’t use car frequently.
B
Buck2003
Thank for that, I feel somewhat happier with my purchase now.
And yes I would like a agm battery charger/conditioner but my car is used daily at the moment.
jays705
Harrow
E350 CGI and Cl63 AMG
I too have purchased many car batteries from Tayna and have recommended them to many
DSK
CLS 320 CDI, S350 Bluetec
You know they will also have pretty fresh stock considering what they must be turning over of all the common/popular items.
I’ve bought 3 of them in the last 4 weeks just for the sake of it knowing my batteries are new.
