New C350e user
KitSiu
C350E
Hi all, nice to become one of the C350e owner, I got mine for a month and found from the forums with numbers of bad experiences in Mercedes hybrid system.
After my one month experience, Mercedes still a very luxury experience even it is a 4 years old. But.... I got the same feeling about the poor battery performance; I have consulted the dealer and reset the meter and result is 3.8miles after fully charged; ive sent back to dealer for “upgrading” the software, after this update, performance improved a lot.... from 3.8 miles to 4.9miles.....
is there any professional could tell me why there is huge difference from the data sheet of 19miles ?
Hello and welcome
Because the tests are done in ideal conditions which are almost impossible to recreate in real world driving.
All manufacturers do it as the tests are comparable
K
KitSiu
C350E
Totally understand, but 19miles to 4.9 miles for my actual result is far below.... i could accept is something about 10
從我的iPhone使用Tapatalk 發送
Anthony Humpherson
C350e
Hi. I also have a C350e 4year old . And I have had it about a month. My car has covered 80000. Miles . So far it's working well . I've got approx 14. Miles sometimes 16 miles of charge,in. When charged complete.
my charger is on a timer, instead of doing the full two hours. I split it into two leaving about an 2hours between. I also let the charge rate go down to at least 10%
Regards
K
KitSiu
C350E
Regards
Thx Anthony, would you mind to share how to work the charger on a timer instead for fully charge 2 hours? U have installed a separate timer for the charger?
SmartAmg
2011 E class coupe 350 CDI
Anthony Humpherson
C350e
Hi ,I have installed a suitable outside 13 amp three pin plug ,wall socket at home . Then use a timer socket set at 1 hour then about 2 hours after set for another hour finishing the charge .
