New Discs and Pads
keets1
Hi all,
im going to have discs and pads replaced at the weekend (due to unbareable squeeling!)
Does anyone know what cost i should be expecting?
The car is MB A class 160 168 edition 99V
Thanks in advance!
Hi all,
Thanks in advance!
The disc do not cause squeal, its normally incorrect pads or badly fitted pads
K
keets1
Sorry - i didnt explain correctly.
The squeeling has been there intermitantly for a while (not during braking) just driving along.
The squeeling has got worse and worse over the last couple of weeks,
When i press the brake peddle slightly the squeel stops as soon as i take off the brakes it begins again. - it makes no difference if im going backwards or forwards or even if the engine is running.
i have presumed that its the brakes that are my problem?
I would not change anything yet, have the old pads removed and check that the pads are not stuck in the caliper, make sure that they have some free play and not dead tight, grease them and put them back
jibcl500
Cambridgeshire
CL500,ML55,SLK280
sounds to me like they need a strip down clean fresh copper grease and a road test, should anything be worn below MB specs then yes replace it, some cars have anti squeel shims and some garages dont replace them.
jib
Agreed, with brakes I always buy MB parts and never alternative parts and I buy them from MB.
jib
I have used EBC for years,clean wheels and never a squeek
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Never tried EBC, always lokking for something else might try them.
jib
jib
They are more expensive than OE Mintex, but the clean wheels are worth it
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Will try them on the wifes SLK she seems to get the wheels black after one day!!!!!!!!!!!
Alloy and brake dust dont mix. Or is that me and the wife!!!!!
jib
K
keets1
Thanks for all your advice guys..
I will get the garage to see what is causing the squeeling before i have any replacments made.
I will of course keep you informed at to the outcome.
Thanks again.
K
keets1
Hello All,
Thanks for all you help and advice,
Having took the car to the garage, they instantly knew the squealing was from the pad being stuck in the caliper, - Once removed the Off-Side was worn beyond belief, the Near-Side was also worn but not as much (is that normal?).
Anyway pads replaced and a greasing later, Perfect.
Also, no new discs required.
I did observe the replacement and honestly thought "i could do that" it seamed to me that all i takes is one bolt at the back of the caliper and a screwdriver to loosen the pads - hey presto.
Am i being naive? Is there is much more to it?
Again thanks!
jibcl500
Cambridgeshire
CL500,ML55,SLK280
pad changes are easy, it always pays to clean things up a little whilst doing it though.
jib
If ever you want to do it yourself, we will always give you the know how
Tel: 020 8863 9233
