New exhaust!
Deadeye-Detailing
S350 CDI
Hi everyone its been a while!
So ive done a few things recently including new pulsation dampner and ABC system flush, while doing Rodio the radiator poped so it had to have a new one, luckily they had one at Milton Keynes, i had visions of them saying they were on back order!
Anyway i also took a trip to Deuchtech in MK for a full exhaust. One of my cats was cra ked so they needed to go, so its a full system. I decided to go for no cats, x pipe, and a stage one map woth pops and bangs.
Anyway a week later it was clear that it was way way way to loud and the pops and bamgs while funny for the 1st 60 seconds were best left for the RS crew. Also they made tbe car judder. So a week later off i pop back to have some silencers put in and take the pops and bangs off.
Its now much better and about 20% louder. You can hear it on insta @theblackcl63_amg
Also i dropped the oil and found the oil pan had a small leak so off it had to come
Once installed it was all toped up with Shell 5w40 along with 2x Liqui-molly ceratech and 2x liqui-molly lifter additive.
Some may think the liqui-molly is snake pil but ive noticed the engine being much more quiet, no lifter noise and runs about 2 deg coole i always use 2x liqui molly flush and run for 15 mins before dropping the oil.
So whats next.
Well i suspect the head bolts are shot, so its heads off time, im going to replace the head gaskets, bolts and while im in there i will be changing all 4 cams for a slightly more agressive cam alon with SLS lifters (not sls black as im not going to super charge it) and also new stage 2 cam adjuster from 63 motorsport in canada.
Also on the way for testing is the development oil catch can system from 63 motorsport for accelerated freal world testing as im doing about 5000 miles a week at the moment.
Oh and a gearbox re build as although the juddering has gone, im not happy with the gear changes so ill be putting in the uprated tauqe convertor from weisstech.
Oh a new amp is now in so i have music again!
Anyway if you want to have a listen to the noise check out it out on @theblackcl63_amg
Lots to do but i absolutly love it!
