New member and need advice
Evan Hale
190E AMG 2.3L 1990
Hello all I'm new here, I need information on weather it is a straight forward process to swap the engine from a 1990 190e 2.3 8v with a 500sel v8 unfortunately the 4 banger blew up a few days ago along with trans and radiator, how ever I have a mint low km engine sitting that would be perfect, all the wiring is there and the v8 runs well, any help would be much appreciated.
Thanks all
AMGeed
Poole, Dorset
S204 C180K
I doubt its a straight forward swap. Engine mount positions are probably different and the springs and shocks will need upgrading to carry the extra weight of the V8.
You'll need suitable transmission too, then the propshaft may not fit.
It reads like it could throw up all kinds of problems.
Hi and welcome.
It has been done but it's not easy.
Gearbox and rear axle are unlikely to be up to the job. The front springs won't be strong enough. Once you have it going stopping could be an issue.
You'll need a complete exhaust.
You'll also need to fabricate a cross member and do some serious metal work around the transmission tunnel and firewall (and that's before you change the gearbox). That's assuming the V8 clears the engine bay inner wings (with manifolds on unless you want to fabricate exhaust manifolds too).
Not at all something to be undertaken without a lot of forethought and access to a lot of tools and time.
Welcome Evan... would be nice to keep it original anyway if you could find another engine ...
E
Evan Hale
190E AMG 2.3L 1990
Hmmm good point, looks like another 4 banger is the way to go would love to find a manual trans to bolt onto it though. I can get another 4 cylinder for around 400$nz but manual transmission is hard to come by apparently.
Hello and welcome
E
Evan Hale
190E AMG 2.3L 1990
What about the 6 cylinder 190e engine? Will that fit?
Different cross member, radiator mounts and exhaust but much easier than a V8.
The m103 (12 valve) and m104 (24v) will both have the same issues. The 190 comes with a 2.6 but the 3.0, 3.2 and 3.6 will be largely interchangeable. Electronic injection versions will be much more difficult.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Hi and welcome to the forum. I’ll leave the experts to answer your questions but hope you manage to get the car running again.
A.J.
Norwich. UK
Hi Evan, welcome to the forum :)
E
Evan Hale
190E AMG 2.3L 1990
Awesome thank you very much I just want a engine that will bolt right in without having to modify anything, I understand that the ecu and other electronic components will need swapping vs the 6 cylinder or latest other things, I'd love to put a 3L in
Welcome!
As above, the easiest thing will be to swap in the same engine. Doing another engine swap, is easiest with a donor car to take all the bits from!
Mrs R Maths
190e 1991 J plate 1800 petrol
Thanks all
I have a lovely 1800 petrol engine awaiting a new home soon (starts on first turn every time). From a donor vehicle for mine if you have not had any joy sourcing something bigger yet. Currently own 3 190e 's in various states of repair as have found that donor vehicles are cheaper than parts.
I think he could be in NZ...
Mrs R Maths
My baby won't start, in fact key won't turn at all and MB say that it's probably the Electronic ignition switch and want me to take it to them. Sounds simple except the key won't turn so I cannot get the steering lock off to get the car off the drive even to have towed there. I own two donor vehicles (same year) is swapping the EIS difficult?
1991 cars don't have an EIS?
