new member thinking of buying used C220d car
pcdoc
C220d Sport Premium 4dr Auto 2016 2.1
Hi have joined forum as planning to buy used Merc 220d. The car I am looking at is a 2016 model from dealer
C220d Sport Premium 4dr Auto 2.1 with appx 63k on the clock.
Checking on its mot history there was a fail the previous mot with
  • Engine MIL inoperative or indicates a malfunction (8.2.2.2 (g))
The car was then passed so I have to hope any issue was properly fixed. The rest of its mot history looks fine and its currently to March 25 with latest test showing no defects.
Just wanted a view as to if I should have any worry re the 2023 fail for the above code?
Car is priced at just over £13k and looks good all round so hopefully a good purchase for me.
Any advice appreciated
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
I drove a slightly later model and found it a nice car to be in. I assume you would be doing 10k+ miles pa to be buying a diesel?
If not I'd be looking at a similar petrol model without the complications of a DPF/EGR and possible ad-blue. All things likely to give problems if a diesel car isn't being driven a lot.
If the new MOT shows no advisories or malfunctions I think its safe to say the previous fault was fixed.
I'd be making sure it has a full and complete service history (every 12 months or 15500 miles), preferably at a main dealer or Mercedes specialist.
Without a full history, you have room to negotiate on the price.
Good luck!
billo2
2016 W205 c220d estate
Hi pcdoc, I've had a 2016 estate version of this for almost 6 years, and have been very happy. 55k miles, nothing major yet... (except frustrations around 4matic crabbing)
P
pcdoc
Good luck!
excellent feedback really appreciated. tbh I will only likely do 8k as retiring shortly so no work journeys just leisure. Might consider researching a petrol version in that case but am attracted by £20 tax on the diesel. One other thought... I think these are a chain rather than a belt. Is the chain a lifetime thing or should it be changed at intervals I think I read appx 60k? any thoughts about that would be helpful
P
pcdoc
Welcome - All Season tyres (Michelin Cross Climate) cured the crabbing on my GLC.
ah thanks for that i did a search on this and found another post on YouTube who fixed this issue by going onto Michelin pilot sport 4 so seems Michelin are the way to go for winter. will check more into this before I buy the car
Srdl
Hampshire
GLC43 AMG 2018 (X253)
So far, I’m about 7000 miles into the Cross Climates and they seem to be excellent tyres, wearing well, although we’ve had no winter weather down south, just rain and a lot if it but they work well in the wet.
Srdl
Hampshire
I would avoid diesel at all costs. AdBlu system problems costs would far exceed any savings from lower road tax
malcolm E53 AMG
There’s no science to timing chain longetivity some last 60k miles and others the life of the engine a lot depends on regular oil changes <10k in my view
Most of the modern chains have been switched to simplex rather then duplex and also turned so it's at the back of the engine rather than the front (for better pedestrian impact) - both of these lead to increased chain wear and more difficult to replace
malcolm E53 AMG
I remember in the day my Dolomite Sprint went through duplex timing chains every 40k miles a real pain in the a**e they sounded like the household cavalry coming down the road when they required doing it was one of the first 16 valve cylinder heads produced and must have had quite a load on the chain
Chrishazle
Nr Ashford, Kent
+1 on that thought, the posts you see on here (and on the MBClub forum) about Adblue/Nox sensor (expensive) problems, I would not touch an Adblue car with a very long barge pole! With diesel now about 10p/l more expensive that 95RON, fuel and servicing cost will be lower on a petrol, although they're rarer than diesels. Member @littlebrooklyn on here had a C250Cgi estate and heavily regrets selling it!
