Judwin
- Sep 23, 2021
- C180/2013/M274
I think I've just purchased my first Merc, and suspect I'm going to need some help to get it into the spec I require. I don't pick it up till next Saturday, but from spending several seconds performing extensive research, I think it's....
C180 2013 (62 plate) S204 C-Class Estate with the petrol M274.910 engine, 6 speed manual gearbox, palladium silver/grey, first registered Feb2013.
My first task will be to give it a full fluid and brakes change before using it as my daily driver. Trouble is, I can't even work out which oil filter it needs. Most petrol S204's seem to use the long thin tube filter(A2711800509), but they're M271 (1.8) engines. This has a 1.6 engine, which I think means it's a M274, but the M274 fitted to S205's use a different filter (A2711800109). I know the easy way to tell would be to pull the old one out of the car for a look-see, but as I said, I don't pick it up till next weekend.
Next issue is the DVLA/VOSA MOT check website says there is an outstanding recall on it. Anyone know what that might be for - it's a petrol so shouldn't be diesel-gate related.
Anyhow, this time next week expect a barrage of questions - some probably daft.
Cheers
Judwin
Cheers
Judwin
