New rules for MOT to test for diesel particulate filter
whitenemesis
CLS55 AMG '05
It was bound to happen.
I wonder how thorough the MoT tester will be? Simply check the filter is still physically present or check it still functions (how?)?
Oh dear,,,, some diesel owner are going to have an expensive time.
toby1
West Berkshire
If it's still present and de-activated then no problem (I guess)
whitenemesis
CLS55 AMG '05
Not according to the regulations, potentially up to £1000 fine for using a car so modified.
"It is an offence under the Road vehicles (Construction and Use) Regulations
(Regulation 61a(3))1 to use a vehicle which has been modified in such a way that it
no longer complies with the air pollutant emissions standards it was designed to
meet. Removal of a DPF will almost invariably contravene these requirements,
making the vehicle illegal for road use. The potential penalties for failing to comply
with Regulation 61a are fines of up to £1,000 for a car or £2,500 for a light goods
vehicle. "
https://www.gov.uk/government/uploa...63018/diesel-particulate-filters-guidance.pdf
Miffy
Bromley, London
CLK 320 CAB Elegance C208
hard to monitor though? as long as the can is there, they do not have to check its working, as long as it passes the smoke test.
coventryslk
Coventry
W204 CDI Sport
oh dear, pre b/e cars like mine will start to attract a premium maybe?
toby1
West Berkshire
Yes, how would the tester know? Same with cats removed but housing present, Shirley?
whitenemesis
CLS55 AMG '05
Yup, pretty sure it'll go the same way as CAT 'removal' the filter opened and gutted etc.. Which makes it all a bit of a farce.
Bit more involved though as it will need mapping out as well. How long before they introduce some sort of ecu inspection? Not just for this but any mod that potentially effects emissions?
The wording of the guidance notes makes no mention of tighter particulate emission values for DPF equipped cars, just the visual check to see if fitted.
However, I pulled this text from the notes...
meet."
So it seems clear, a car with only the internals removed, and with an engine 'remap' to allow the car to run correctly is illegal, but will not fail an MOT test as long as the particulates are lower than the (currently VERY high) pass value.
Whereas, a car with a 'link pipe' fitted, or with obvious evidence of DPF tampering will fail.
Be nice to have a contribution from one of the remappers on this...
Alex the one with the hole drilled in it comes to mind ;)
whitenemesis
CLS55 AMG '05
meet."
I suspect they will introduce another type analyser and/or reduce the pass level?
They cannot reduce the pass level, that is EU set and the cars have all been built to pass within the set level.
Rory
Cheshire, UK
More and more I think my next car will need to be petrol.
exjag
Leeds
E350 avantgarde 2010 3.0
The solution is to just leave the b****y thing alone. The filter is there for a purpose, which is to minimise health risk, especially to kids with asthma.
yorkshire1
East Yorks
"98 S202 C250TD Manual hybrid
exactly how
So the particulate filter is there to trap whatever it was designed to trap but then during the regeneration stage is the same crap not blown back out again
ie pootling about town DPF traps crap to keep punters happy then once you warm up and put your foot down int country give em it back again??!!
It gets recycled
M80
Derbyshire
DPF means higher consumption, sounds like a contradiction me thinks.
Wait for the argument at MOT when the guy says, "your 2005 car has had the filter removed".
Have I to produce information from the VIN to show it never had one ?
whitenemesis
CLS55 AMG '05
The diesel particulates burn off in the higher exhaust temps during regeneration. The resultant waste if far less harmful.
whitenemesis
CLS55 AMG '05
As now with CATs, the test station will have a database of which cars originally had filters fitted.
