New shoes for an old horse
furiouskudoka
'00 W203 C320 petrol
Hey guys
I have went through the few threads about it, however I would just like to check your thoughts
I currently have a set of 205/55/16 tyres on my C320 which are due for replacement
The fuel tank cap says 225/50/16, however I've been fine with the smaller tyres for quite a while
Is it worth paying the premium, or should I roll with the cheaper and more common size ?
P.S - what's the largest size you have fitted in a W203 ? The C32 AMG comes with 17's, is this the optimal size?
I have 205’s front and 225’s rear for summer and 205’s all round on my winters.
I expect you’re on the winter setup.
malcolm E53 AMG
If you are happy with the 205s I’d stick with them the 225s will alter the characteristics of the car. The best set-up I’ve had was a S210 with 215s all round which gave enough grip, no tramlining and great feel even on our third world roads.
I see loads of 275’s and 285’s on 220 diesels and wonder why would you put yourself through that expensive hell just for fashion???? o_O
malcolm E53 AMG
I see loads of 275’s and 285’s on 220 diesels and wonder why would you put yourself through that expensive he’ll just for fashion???? o_O
Agreed, no point whatsoever unless you are a tyre manufacturer in which case it’s a win situation (they must be making a fortune out of it)
AnthonyUK
Alton, Hants
C240 estate 2002
I bought a staggered set of 17" wheels from the breakers for £100 which I think came off of an SLK which would be the ideal size for a C320.
The rears are a little uncommon but still enough of a choice available so 225/45 R17 and 245/40R17.
I really wanted Crossclimate+ though so ended up with 225/45 all-round o_O
These are the original 16" which I refurbished.
BassMerc
Broadway
GLC 250 AMG Premium
So, an old horse, any horse, has new shoes every five weeks. If only we could afford to change tyres with the same frequency.
F
furiouskudoka
Looks solid !
I am trying to find the C32 wheels in decent shape, but to no avail
JBell
Torquey
C350 CDi Estate (GAD Edition)
JBell
Torquey
I has 8x17" ET35 wheels all round fitted with 225/45 R17 front and 245/40 R17 rear tyres on my W203
Madtutle3
Halifax, Nova Scotia, Canada
A250 / 2021
The 205/55/R16 doesn't affect your speedometer (0.1%) difference) compared to the 225/50/R16.
However, you are giving up 9% (8.9%) of the contact patch with the pavement . This will certainly affect the braking and handling of the car in demanding circumstances.
An alternative would be 215/55/R16. which gives you only 4.4% less contact patch. Your speedometer will read 1.8% differently. eg if the speedo says 80 your actual will be 81.46, which is actually not a bad thing as all speedometers I have seen read low by 1 or 2 mph.
Gazwould
C250 CDI
How can you apply maths to tyres ?
Madtutle3
A250 / 2021
I should mention that I have an old Subaru SVX which is a touring coupe. It was made from 1992 through 1997. The OEM tires were 225/50R16 except for the 1997 models which were changed to 215/55/R16. I've driven both on that car and prefer the 225.
Gazwould
C250 CDI
Trouble is tyre manufacturers don't keep to the widths and aspect ratio stated on the sidewall .
Gazwould
C250 CDI
They manipulate to make the tyre perform in different areas , width - gip or economy , profile for handing or comfort .
It all started when I noticed a significant ride height change on a low car on coilovers when upsizing some wheels .
AnthonyUK
Alton, Hants
C240 estate 2002
I beleive the allowed limit is 3% which is hardly anything. Any more would impact speedo readings etc.
Uncle Benz
West Sussex
Mainly Mercedes
18” were the largest factory fit on the w203 platfom, on the C55 AMG. I have a set on my C32 as the summer wheels, with the original 17’s reserved for winter with Kumho KU27’s on.
18’s pictured here. 225/40/18 front, 245/35/18 rear
Uncle Benz
West Sussex
Mainly Mercedes
These are the original 17” wheels. 225/45/17 front, 245/40/17 rear.
Very similar design. The spokes are just a bit longer on the the 18’s
