Newbie here need a scaner for a 2004 ml270
geoffdown
ML 2004 2.7cdi
Hi guys bought a 2004 ml270 with bas/esp light on only. Traction control works fine and abs works fine. Tracking was out but now sorted but light still on, need a scanner that can read all codes and reset them un like my phone software please help mot end of month
mioba
Nottingham and Köln
where are you located, pop to a merc indy if one nearby or a MB dealer
deleting the codes may not clear the fault, unlikely tracking is the cause of such faults, mostly related to ABS sensor, or impulse ring.
Taffy7hfa
Oxford
Your welcome to use my MBII if your anywhere near Oxford.
G
geoffdown
ML 2004 2.7cdi
Sadly in sunny Devon but thanks what have you got I don't buying a scanner
G
geoffdown
ML 2004 2.7cdi
England but as already said all other systems work perfectly so got to be either steering sensor on steering wheel or lateral acceration sensor
Taffy7hfa
Oxford
ICarsoft MBII, its a pretty decent bit of kit.
Taffy7hfa
Oxford
Think the mbII is still available, although there is an updated version as well I believe.if you're thinking of buying one be carefull as there are plenty of Chinese fakes out there.
iCarsoft MB-II is quite old now and superceded by the MB V2 which has in turn been superceded by the MB-V3.
Alternatively the iCarsoft CR-Pro and CR-Max cover other models as well as Mercedes but cost more.
G
geoffdown
ML 2004 2.7cdi
This is the one I have bought hopefully it will read and reset the bas/esp light will let you know how I get on tomorrow nite.
AnthonyUK
Alton, Hants
C240 estate 2002 and a Nissan Elgrand E51 ser.3
I think even the lowly i980 would do that so the models higher up definitely will.
G
geoffdown
ML 2004 2.7cdi
OK so the code reader turned up. Very good piece of kit. Can even read all the sensors and came up with signal from component N49(steering angle sensor)is faulty. When looking at data from said sensor it just reads 0° so where can I get a new or working 1 and how easy is it to fit.
Taffy7hfa
Oxford
Worth checking it's not this , it's a common problem on the w163.
G
geoffdown
ML 2004 2.7cdi
Thanks for the pointer but my code reader is saying its steering angle sensor it's not giving any live data and saying the signal from n49 is faulty
Taffy7hfa
Oxford
Ah , that's probably it then, they do break, it's like a giant clock spring at the back of the steering wheel .
G
geoffdown
ML 2004 2.7cdi
  • #18
Where can I get this steering angle sensor as mercedes is saying its no longer available
Taffy7hfa
Oxford
That would be the type of part I would normally get from a car dismantler. Although I hate ebay it can be good for secondhand parts, at least you know it will be a genuine mercedes part.
joderest
ML270 2003
I feel your pain, had the same problem with my W163, but after a lot of fault resets, ended up with just ABS light on, which would not go away and fault code said "perform road test", i found the test, performed it, and 4 years later still no light.
They can be a bugger when they go wrong !!!!!
Tel: 020 8863 9233
