Newbie question about C-Class Estate Bluetooth
T
timnwild
We just bought a 2004 C-Class 180K this weekend, which so far is proving a great car. But we can't figure out how/if we can connect an iPhone by Bluetooth. There's no aux connector in the glovebox. Found lots of conflicting/confusing advice on the web - any owners out there can help?
V6Matty
Newark, Nottinghamshire
i would suspect you have an audio 20 installed in your car, do you know if you have telephone pre wiring? if not then it's not that easy to add bluetooth if you do then it's worth speaking to the guys at "Command Online" (forum supports here), they will be able to gibe you the options that are available.
Brian23
EClass
Hi, mine is in the centre arm rest. If you search on your phone won't is see it, if there is a Bluetooth system fitted? Hope this helps a little,
Brian
www.ckinsurance.co.uk
