corradoman
- Feb 2, 2009
Hi all, Ive just bought a clk 320 1998 and it has a couple of problems! and wondered if you could help! It will start and run happily for about 15mins and then just cut out as if there is no fuel and then you have to wait for 20 mins or so for it to start again! Then it will run for another 10 mins or so and will do the same again I am going to try a fuel pump relay first and then maybe a pump which is going to start getting costly I have had it diagnostically checked by mercs proper software but is not finding a fault code! I just wondered if this problem has come up on her before with a possible sollution before i start spending lots of money Second problem is the heater blower not working it is the panel type heater control with the aircon and push button control, would this be bushes in the motor as with the other threads..
Thanks in advance
Thanks in advance
