Bybuys
Hi All
Thisi s ths 4th car forum I have joined since retiring 18 months ago. The others, Citroen AX, MGRover, Fiat and Saab have all been to do with helping others fix their cars which is a hobby of mine but I have never had the guts to do anything on my 230 CLK Avantgarde Convertible but now I have a problem. The car is a 2001 auto/tiptronic. Used it a week ago and put it into Drive and noticed it was not changing up thro the gears. Returned and tried it the next morning and it drove perfectly well as if there had been no problem. This has happened about 5 times now when it wont change thro gears and there is no response from the tipronic (just stays in the same gear and displays D) When I stop, turn off the ignition and then back on again, most times it works fine and tiptronic works perfectly. Occasionally have to try a couple of times but it always works and then does the same thing a day or two later. Similar problem a couple of days ago when moving from M5 to M4 motorway. Had to kickdown to get in front of a lorry which it did fine, eased of the gas and then when I used the accelerator again there was no drive and engine just revved. Went to hardshoulder moved gear lever from Drive to Neutral and back to drive and it took off now problem for the next 100 miles on motorway and a and b roads. I have no idea where to start but thought best to get advice of those in the know before I took to a Mercedes dealer/independant. Any thoughts/advice would be appreciated
