Dean Fletcher
- Mar 24, 2018
- Location
- Penrith, Cumbria
- Mercedes E400
Hi guys,
My indy is having a bit of a nightmare, my car went in needed a new temp sensor last week that was fitted then a day later it's came back up. He now thinks that there could be a wire grounding in the car somewhere for it to be keep going off. He did notice that the plug that connect the wires from the sensor to the ecu was dirty and not fully closed. So he has cleaned that and replugged. Basicly one heat sensor is showing 60 degrees and the other is showing 4 degrees which the later one would be correct. I'm not keen on him taking the car apart to find it if it is loose? Do you have any suggestions or ideas what could be causing the issue. Thanks in advance
