Parkheadlad
- Aug 26, 2022
- Mercedes Benz CL 500 2004
No response from my CL 500 (2004) when I used my fob to unlock the doors. Battery is fully charged. For the last 6 months I have had a parasitic draw (0.28A) from the battery so any time I parked up I removed the negative lead from the negative battery terminal. Never had a problem starting the car when reconnected. Recently I parked up for 9/10 days and as stated above a ' dead' car when I reconnected the negative lead. Reluctant at the moment to open the driver's door manually with the key as the door and windows are soft closing - closing the door will not be 'true' as the driver's window will nor reset due to lack of any power. This happened once before - I simply disconnected and reconnected the negative lead which solved the problem.
Any thoughts very welcome.
