No phone on Command screen but phone in cradle...
j33per
Somerset
www.j33per.com
I have a 53 E320CDi with Command and have been using my Nokia 6310i happily in the under armrest cradle. For the past couple of months I haven't used it as I got myself another phone.
Today I received my second SIM card with a view to leave my old 6310i in the car and carry something more up-to-date around with me.
Now, the Command screen shows "No phone" even though I definitely have the phone securely in the cradle. I have tried it with another person's 6310i also but still the same message.
Am I missing something?
jberks
check the connections at the bottom of the cradle for dust or muck. I normally run my finger across them a couple of times.
That normally does the trick.
If it's UHI (i suspect not on a 53 but anyway), remove the cradle (small button top left and pull down) and blow the dust off the contacts on the plug and socket underneath.
As Jberks, very good advice
Alfie
Surrey/Cotswolds
www.comand.co.uk
Iv'e seen this before and a reset of the MOST ring fixed it. Failing that a complete power off of the comand unit should sort it unless there is a fault on the MOST bus itself.
Either way, you'll need a trip to your local dealer to get the MOST bus reset. You can try a complete power cycle of your AGW which is in the boot on the left side.
j33per
Somerset
www.j33per.com
Thank you Alfie! I have her booked in for Thursday and will post what my dealer (MB Taunton) has had to say.
j33per
Somerset
www.j33per.com
Fixed today. It needed another phone controller. Total damage including VAT £430. Bah humbug.
