No power after batt disconnect
duc600ss
1998 W210 E240. After diconnecting/reconnecting my battery I am unable to depress the accelerator without stalling/reducing revs, as soon as I ease off the throttle the revs return to normal idle. Can anyone think of something I need to reset or any advice is welcome.
Duc600ss
mebobster
i own an R reg 300TD. but my mum drives a BMW318, i had a similar problem when i put a new battery in for her. turned out that i should have waited a few minutes after re-connecting new battery so the ECU & relays settled down, i know it sounds bizarre but thats all it was. perhaps you could disconnect & then reconnect battery, wait for a short while, & then try? just an idea to start with...
D
duc600ss
throttle cable is fine, as it does the same if I rev from engine comprtment. It really has changed only since the batt reconnect
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Disconnect the battery and leave for an hour, reconnect the battery start the car and let it idle for 5 mins, turn off, restart and go for a drive.
jib
D
duc600ss
I tried mebobster's thought of leaving it for a while and no change, I've disconnected and leaving for an hour or so as jibcl500 recommends. I'll let you know later. Thanks
jibcl500
Cambridgeshire
CL500,ML55,SLK280
You havent refitted the battery the wrong way round have you.
jib
panason1c
Somerset, UK
Duc600ss
Try this.....nothing to lose.....
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.”
D
duc600ss
Okay did what jibcl500 recommended, took it for drive still having issues having to release throttle to maintain any power . Also did the throttle reset and no difference either.
alancee
southampton/ferndown
wierd
do you have any other lights up ,ie abs staying on and visit shop or something,if you disconnected the the battery then reconnected you should have,if you have lights up ,start the car,turn steering wheel fully left,then right,do it again,i know it sounds stupid but its in the book,try it any way,it resets stuff.
Xtractorfan
S class
Get it checked on a star machine it must have stored faults that it cant reset
D
duc600ss
No lights at all. As far as Star, can that be done at any garage or does it have to be MB
D
duc600ss
Does anyone know of a workshop in the Witney (oxon) area that might be able to help as totally useless without car.
Duc600ss
mebobster
cruise control?
if your merc has cruise control, why not double check it? just a thought mate...
star
Reading
Smart + others :)
I expect your air mass has failed, they sometimes do this when the battery is disconnected.
D
duc600ss
  • #18
I have come across a MAF from Webcon selling Magnetti Marelli MAFs. I have used Magnetti products before on my ducati but unsure how good on car . Anyone come across this MAF before? Looking to get one soon and this is a reasonable price.
D
duc600ss
  • #19
mobile again
Thanks Star ,spot on bought magnetti marelli MAF and now it works fine again.(see how long this aftermarket one lasts) moral is not to disconnect battery I guess. Thanks to everyone for your inputs.
Regards
Duc600ss
