brandwooddixon
- Jul 31, 2006
- Location
- Wolverhampton
- S63 Coupe 2014
My previous car had Keyless-Go.There is a big difference between keyless go and keyless entry. The ones that can be stolen easily have keyless entry. The signal is picked up remotely using a computer and then the car is unlocked. It can also be driven away as the laptop forms the key so the car thinks the key is present. If you only have keyless go however, it is much harder to gain access to the car as you can't simply touch the handle to unlock it as will keyless entry.
It allowed you to unlock the car by pulling the door handle and start it by pressing a button on the gear selector knob to start (or stop) the car or you could use the key as standard in an ignition slot to the right of the steering wheel..
From what you describe Keyless-Go has changed for the newer cars.
