No start, no click, no nothing!
ghunter1234
1998 SLK230
Hi all, first time poster here! I’ve got a 1998 SLK230 as a project car, of sorts. Hoping for some suggestions:
When I try to start the car, nothing happens. No clicking, nothing. The engine doesn’t even try to turn over.
The battery is good. (Double and triple checked).
Ive replaced the entire key/ignition/steering wheel lock assembly, and along with that the immobilizer, door locks, ecu, and now I’m using the new key that came with it. Didn’t help.
The only other clues I have is that the car sat in storage for a while- iv already spliced some mouse-chewed wires. Maybe there are others I’ve missed.
Also, I attached a code reader and got this odd message, picture attached.
Any thoughts, suggestions, leads would be greatly appreciated!
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Good morning,
the code reader suggests power problems, if the ignition is turned on at this point.
mioba
Nottingham and Köln
Welcome.
My first thought was battery but you answered that.
Check the EIS.
star
Reading
Smart + others :)
Check the k40 relay fuse board.
Frontstep
T210 320cdi
Well as no4 but do you have lights etc?
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
Further to what Star says I'd be taking a meter to the fuses to see how far power is getting and to what.
Noddy 99
Telford, Shropshire
2009 W211 E-Class E280 Sport Estate (OM642 3-litre diesel V6), 3x remapped, now returned to stock
This happened to me just once, a few days ago. Been fine before and since. No idea why but it took me 4 attempts to get any reaction - ignition on, dash lights on, nearly new battery but turning the key failed to engage the starter motor; just silence...
G
ghunter1234
1998 SLK230
I have checked all the fuses to make sure none are blown. Is there a way to do anything more thorough than that?
star
Reading
Smart + others :)
Doubt it’s a fuse, more like the board.
mattkh
England
A160 W168 1999 1.6
What happens when you apply power direct to the starter motor..?
G
ghunter1234
1998 SLK230
Thanks.
Soooo it fires up and then stops.
I would look into the immobiliser in that case.
Due to this issue, but also issues turning the key I bought from eBay a set- new key, ignition/steering wheel lock, immobilizer, ECU and door locks.
This fixed the ignition problems but didn’t help get the engine started.
I’ve checked fuses and they seem to be getting power when the ignition is on position 2.
mattkh
England
A160 W168 1999 1.6
Thanks.
What have you done in terms of the old fuel in the tank...?
