SomethingRattling
- May 10, 2006
Busy week so far with my C240 (W202 2000yr). First in the body shop for a bit of touch up on the rusty wheel arches and tailgate, this is becoming an annual event due to the water based brittle paint problem though £175 pa is a small price to pay to keep it looking good. Fitted a replacement window regulator (OS Rear) bought for £55+VAT from Charlton Auto Parts (www.charltonautoparts.co.uk). Still to fit rear discs and pads, discs from mercman £20+delivery and break pads all round (Halfords Front £27 rear £47 Gulp!). So all looking good except for the whining, no the wifes away this weekend, so possibly the diffs I think? I have read a lot of entries in the forum relating to whining noises that could possibly be attributed to wheel bearings, breaks, propshaft couplings etc. So before buying anything I wanted to establish where the noise was coming from. So I bought a pair of axle stands from halfords (£9.99 the pair) and wheel chocks (£4.99 for 2) placed the chocks under the front wheels jacked the rear up using the standard MB jack and slipped the axle stands pretty much under swing arm just below the suspension spring (having removed the plastic cover) did this on both sides. The car was facing the garage which is full of car boot junk, so I thought was expendable if the car fell off the stands! Made sure the dog, kids and every body was well clear of the vehicle. Pushed the vehicle a few times to ensure was stable then started the engine. Boy! did the traction control bitch! but never the less I was able to wedge the accelerator enough (gradual build up) for the whining noise to be heard I guess about 30mph?. Next using a large carboard tube, about 4 ft long, I was able to lie down at the side and rear of the car and listen through the tube (directional hearing) and YES the whining was definatly louder at the diffs! Now I did ask about replacing various parts of the diff, crown pinion, bearings etc. but it was pointed out that due to tight tolerances and special tools it would probably be best to find a differential specialist. But now having been able to look under the vehicle I notice that the propshaft joint and drive shaft joints look fairly straight forward to disconnect and a replacement of the unit may be easier? so my questions are:
Is the replacement of the diffs fairly straight forward in this manner?
If so the can anyone tell me how to identify the gear ratio?
PS I have had the oil replaced in the diffs but made no difference to the whining.
