Non-cat front pipe
Status
Not open for further replies.
flyingtech55
Ayrshire
www.bordersgliding.co.uk
2003 SLK320 (R170)
Can anyone recommend a non-cat front pipe for my '92 190E 2.0L. The original is/has breaking/broken up...its rattling from inside. I've checked up with the MOT station and my car doesn't need a cat because it's an early '92 so doesn't fall with the regulation. Unfortunately, on these cars the cat is part of the front pipe which runs from the manifold to the centre box with no joints. In other words, I can't easily insert a by-pass section. However, it needs to have the fitting for the Lamda sensor to screw into.
What I'm after is an after market non-cat front pipe (preferably in stainless steel) which is a direct bolt-on part to replace the existing one and which has the fitting for the Lamda probe already in place. My car is the version with the twin tail pipes and the twin down pipes from the manifold.
Thanks for any help you folks can provide.
Status
Tel: 020 8863 9233
