Non starting diesel.
Bohemian
Hi everyone, have a curious starting problem with my 2000 S320CDI. Occasionally when I`ve left it for 10 or 15 mins it won`t start. Always starts on the coldest mornings, and on the odd occasion that it won`t start, if I try it an hour later, it fires up. It is always warmed up when it happens, and the starter turns and turns, but just won`t fire up. Anybody have similar problems? Many thanks in advance, Brian.
sarkyanimal
west country
s320 1955 triumph tr2 + cls 350
hi brian i have the same problem and have after having it diagnosticly checked that it may be the camshaft sensor or the crankshaft sensor good luck
flagstaff
York
'94 E220 Cab
... yeah, definitely sounds an electronickly thing. Needs something plugged into it, like a computer or something.
Seriously.
rich599
huddersfield
www.doodes.co.uk
w204/sprinter/vw t5 autosleeper/david brown 880/david brown 950
i had the same problem a few years ago on mine it was the camshaft sensor
B
Bohemian
Many thanks for the suggestions, at least have an idea where to start.
If always associated with hot starting, that crank sensor is top suspect, as has been said.
I missed this one and easy CPS thanks Alex :D:D
B
Bohemian
Many thanks for all the advice, replaced the crank angle sensor and no more problems.
