Normfest Inject-Crack - Injector, Glow Plug and Spark Plug Loosener 250ml Any one ever try this
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
Was going to remove glow plugs soon anyone ever use this stuff , I was going to keep soaking for 1-2 wks before attempting. cars in garage so can keep spraying every day as not going to drive it till I get it cleaned up.
bembo449
gainsborough , lincolnshire
I reckon no matter what you put on them , if they are going to snap they just will pal, no one can say that it defo helps to use these things as they never tried without it ! I say warm the engine up and cross your fingers
mercmancdi
mercmancdi
yea I have done them before no bother but there’s so many stories now it would scare you.
Probably just lossen off air intakes
so there are ready to lift off and get up to temp and give it s go. Gently.
bembo449
yeah there is pal and sometimes this relatively simple change can become a massive headache but ive never put any thing on to soak them , juts warm the engine up and hope not to burn myself
Yes , getting your tools all laid out ready to go and loosening the air boxes makes for a flying fully hot start to be attacking the plugs . I’m sure with 2 weeks of pre soaking they will come out easily .
Maybe set your torque wrench for low torque initially when you loosen them ? (5-8nm)
mercmancdi
mercmancdi
Thanks that’s what I will do.
Just after ordering small torque wrench as mines to big.
