Not the brake light switch
Timbo
Dorset
Just my luck, the ABS, BAS and ASR lights are still on after changing the brake light switch. I suppose its a trip to the local dealer, unless anyone has any other ideas.
Incidently, I ordered the brake switch from Eurocarparts on thursday night, it arrived saturday morning, cost £9.59
Regards, Timbo
Just thinking, the lights are on in key 2,you start up and the lights stay on, ABS as well
Malcolm
T
Timbo
Dorset
Yes, lights are on all the time, with just ignition on and with engine running, they don't go out. Bulbs ok also.
Timbo
stats007
Hampshire
Looking
Did you try the steering wheel lock to lock reset?
T
Timbo
Dorset
No, preumably I turn the wheel from lock to lock with the engine running.
I'll go and try it now.
Timbo
Timbo,what is the car. and first 9 numbers of the VIN
Malcolm
Ultymate
N. Wales
C230K Estate 1998
Timbo do you mean the brake lights are on all the time when the ign is on?
T
Timbo
Dorset
The ABS, ASR,BAS warning lights come on as soon as the ignition is switched on and don't go out once engine fires up. The car is a 98 c230k sport. 2020242.
Thanks for your continuing interest,
Timbo
T
Timbo
Dorset
Brake lights work as normal, the ABS, ASR and BAS warning lights come on as soon as the ignition is switched on and don't go out.
Thanks for your continuing interest. Timbo
dava
The Toon
Worth trying to disconect your battery if it's a stored fault code it might clear it. If it does and when you drive it it comes back on then there is a current fault some where in that abs/brake circuit, possibly pad wire or abs sensor.
type49
With the key out, have a look at the BAS control unit, under the brake servo about 5" x 5" and has, I think 3 plugs on it. Quite fiddly but unclip the plugs and check for corrosion on the pins. The plug nearest the engine is prone to letting in water.
T
Timbo
Dorset
Tried the battery thing, no joy. Too dark now to look at the Bas control unit, but what colour is it, do I access it from inside the engine compartment? from memory there doesn't seem to be a lot of room down there.
Thanks, Timbo
type49
Thanks, Timbo
It's black & under the brake master cylinder/servo area, under the bonnet, drivers side & you're right, there's not a lot of room. Good luck.
eric242340
Banned
China
you have a wheel speed sensor problem.you need to visit the workshop sorry.
T
Timbo
Dorset
  • #18
You're dead right, just got back from my local dealer, front os speed sensor faulty, £100.
Timbo
