Ding009
- Mar 8, 2023
- 2015 Mercedes CLS 220D Shooting Brake
Good morning All,
Been a while since I posted, but hopeful you guys can help me resolve an issue, which I know has many posts already on here. (Mercedes CLS 220D 2015 Shooting Brake)
Apologies for repeating a post that has been done many times before, but hopefully mine is a little different as will pose some hypotheticals.
I currently have an amber engine light, which reports as Nox Sensor 2, Bank 1 Malfunction. Following this issue, I then started to get "Ad Blue - Engine Start not possible in 500 miles" which of course is counting down. Upon clearing the fault, it resets the Ad blue issue, and clears the engine light. This may last a day at best.
Currently I have made sure there is plenty of Ad Blue in the tank. And have also removed the Ad Blue injector under the car and cleared off the crystallisation from the injector and entry point on the exhaust. So happy that is clear.
This brings me to my questions. Due to the fault, I assume the Nox Sensor 2 is going to need replacing. Can this be done independently? Or do both Sensor 1 and 2 need changing together? I know main dealers suggest changing both, but is that necessary?
Second, and this is the part I am really hoping for help and experience. Once the sensor is changed (whether 1 or both), does the Mgmt System need to "relearn" the new sensor? And does this "Relearn" process need to be triggered by a good Mercedes Xentry style system, or is there something else that can be done around this? I was thinking something similar to take the battery terminals off? Or anything else? Will the car even start if I were to change the sensor in my garage and not trigger this relearn?
Finally (you'll be glad to read) is there a minimum requirement or type needed when buying a new Nox Sensor? Original research suggested this was a main dealer part only, but have since read this is not true. There seems to be quite a variance in price on these, so want to make sure I get something that will suffice and not just the cheapest.
Your help on this would be very much appreciated.
Thank you in advance
