RickyA
- Sep 11, 2022
- Location
- Dunfermline, Scotland
- CL500 2009 5.5
Hi All, noticed yesterday NSF suspension dropped real low.If I start up and raise suspension to full height, raises OK.If I then ‘drop’ to normal height and switch off engine, immediately drops again.Any ideas / suggestions greatly appreciated.Hoping it’s not an expensive strut replacement !
Additionally, there is what looks like some kind of filter that rests beside the ABC fluid reservoir with a sort of sponge material around it.I think the ‘sponge’ is there as maybe a damper to to stop rattles against body of ABC reservoir ? Amy ideas as to what this component is ? the spongy bit is wet with ABC fluid / oil and wondering if this is possibly the source of suspension dropping on this side.Checked the reservoir level though and all OK. Been dreading the day I experience an ABC issue and after 4 1/2 years of ownership it’s happened and hoping it’s a simple fix ?
All replies, suggestions will be greatly appreciated.216 series 2009 CL 5.5
Ricky
Ricky
