O no more problems--w210 auto box fault any help please?
brad190
Cheshire
Hi all,
I started my e320 cdi tip today & selected drive which was a bit jerky.
I then drove off but it wouldn't change to second gear.
I tried turning off & turning off in drive but still the same problem.
When I select drive or reverse it bangs into gear.
Also it won't go into reverse from drive unless I take my foot off the brake.
Any help galdy received again :D
The brake light switch is one thing,,and worth a try at £10 but no guarantee of a fix
On some cars the throttle cuts if a foot is on the footbrake, is the fluid level OK
colechelle
Resigned
sounds like the one of the speed sensors in the box has failed, hence the bang into gear!!
B
brad190
Cheshire
Thanks very much for your help, so could this be the problem for it not coming out of first gear and where abouts is the switch situated?
Thanks again
I think that colechelle is nearer the mark than me on this, the bang being the giveaway
brandwooddixon
Wolverhampton
S63 Coupe 2014
I hate to worry you, but get it checked.
The only warning that my gearbox gave before it failed was a very harse banging into gear from nuetral to drive.
B
brad190
Cheshire
Hi again,
spoke to mb dealer they said it sounds like the gear selector as the selector indicator on the dash stays in park irrespective of where the gear lever is.
If its a speed sensor would that still make it jerk into gear at standstill & lock out reverse while my foot is on the brake?
I think its gonna be a few pennies whatever:(
Cheers guys.
colechelle
Resigned
Ah, you didnt tell us that before, yes, selector u,s, thats going to be cheaper than first thought!!!
OK I understand the bang now,, you select D and nothing happens as contact has not been made,,contact is made and bang as the engine is revving, that fits.
colechelle
Resigned
thats a diy job as well due to no coding needed on that model!!!!
B
brad190
Cheshire
Whoops no but nearly right lol.
I start the car put my foot on the barke then select D & it engages but with a jerk,
then pull away but it stays in 1st.....i then pull up & it will not go back into P unless I take my foot off the brake.
The dash is saying P whatever I do.
I can repeat this over but still the same results.
Thanks.
colechelle
Resigned
yes, sounds like the selector u,s, seen a few A,class doing the same!!
Will it help if I can find a paper on how to set up they gear shift, and parking indicater
B
brad190
Cheshire
Hi television & colechelle,
Is the selector expensive do you know?
Also television I'm not sure what your asking excuse my thickness please.
Thanks again.
Thanks again.
I am going to take a look to see if I have some instructions for setting up or replacing the selector module. is your car a 210026 or 210226 please
colechelle
Resigned
no point Malc, undo the "C" clip, couple of plugs and refit, nothing is changed, the adjustment is made on the selector rod, but seeing as the ESM will be the same theres no need for adjustment!!, kind offer though!!!!
colechelle
Resigned
Start to finish will take about 20min, done them road side!!!
B
brad190
Cheshire
  • #19
I,m not sure which number but I can look if you tell me where.
I think this maybe beyond my capabilites?
Merc dealer said it would be a few hunded quid.
Cheers.
www.ckinsurance.co.uk
