Ok, you 1.8 owners.
Anyone of you know where the O2 sensor (or connector) is found on my 1991 190e 1.8 RHD (Euro)?
On other forums, they keep mentioning the passenger footwell area.
I've found thick wire insulation going across the footwell from left to right, and it exits the car thru' a rubber grommet near the tranny tunnel.
I split the insulation and found six wires, 2 x purple/white, black, black/red, light brown and yellow grey.
Looking under the car, the wires travel under the car thru ' a black corrugated flexible hose and goes to the tranny.
There, a smaller corrugated hose branches off from the bigger one and disappears behind the tranny.
I think that of these 6 wires, some are for the tranny and others for the O2 sensor.
Anyone know?
Btw, I made a DIY wire harness at the footwell area so I could extract voltages from the 6 wires with respect to ground.
Engine on at 83 deg :
Purple/wht 1 = 0.03V
Purple/wht 2 = 0.03V
Black = -0.04V (neg?)
Light brown = 0.04V
Black/red = 13.54V (obviously battery voltage at idle)
Yellow/grey = 0.04V
Cheers.
Anyone know?
Light brown = 0.04V
Yellow/grey = 0.04V
Cheers.
