O2 sensors heater and turbo control valve circuits low...
93blade
sheppey kent
cl500 2002
Hi, help...
I have reduced power and multiple fault codes on a 2010 cl500 blue efficiency bi turbo v8.
I am assuming it is an electrical issue as too many components failing. I've checked fuses and some connectors and wastegate valve has 11 ohms resistance. Also coming up on dash is cooling fan fault. Not sure where to turn at moment. Some pointers would be good. I'll attach screenshot of faults..
Many thanks
Steve.
ajlsl600
france
How is battery. Or batteries? Use decent code reader note all above. Clear all see what comes back. Then Google the codes. Go from there.
93blade
sheppey kent
cl500 2002
Battery is good. Not that old.
ajlsl600
france
Read codes. Don't own modern benz without decent code reader or deep pockets. Modern benz, n prob most others are DESIGNED to take money off you. ABOVE and some basic ability, interest is only way to mitigate this designed in feature.
93blade
sheppey kent
cl500 2002
Quick update, found fuse 23 20A blown. Blows as soon as I replace. Pulled relay c for terminal 87 engine and fuse doesn't blow. Disconnected turbo solenoid valve and evap control valve, also unplugged fan. Still blew. Just need to unplug o2 sensors and see what happens then. But they seem to be a pig to get at...
93blade
sheppey kent
cl500 2002
Checked everything now. Fuse 23 still blowing and has a short to earth on dead side of fuse. Unplugged o2 sensors but still no joy. Wiring all looks good as far as I can see..
93blade
sheppey kent
cl500 2002
Hi. I have a cl500 bi turbo 2010. It's blowing fuse 23. I've unplugged o2 sensors, turbo control valve and evap valve, also cooling fan, but fuse still blowing, wiring looks OK not sure where to go next.. Wiring diagram would be helpful...
ajlsl600
france
If blowing fuse and all attach components isolated(dissconected) u have a wiring to ground issue..
93blade
sheppey kent
cl500 2002
That's my thinking. But really struggling to locate at moment. Fault codes read all o2 sensor heaters low, turbo wastegate solenoid low and also have a cooling fan fault. Didn't know if this was on same supply.
ajlsl600
france
If one of them is blowing fuse. First test is all connected. New fuse , see which one blows fuse . Money on cooling fan. Or wres to, from. But check all.
93blade
sheppey kent
cl500 2002
Update... Fixed.... Sort of.
Fuse 23 feeds term 87 engine. Located this connector in plastic cable trunking underneath ecu unit. They are red with green stripe wires. Had to separate wires on this connector and test each one to earth. Found the culprit and tried to trace but seems to go down rear of engine under throttle body somewhere. Left disconnected and crimped the rest together. Replaced fuse and all held up. Cleared faults and engine and fan etc all back to normal with full power. Took for a test run then done another scan with a better scanner, thinking disconnected feed would throw up a fault for me, but no faults found and all is working...?
Has anyone got access to engine wiring diagram for M278 engine?
93blade
sheppey kent
cl500 2002
What engine ecu connector number does it go to? If multiple wires crimped into one, you are describing a Z connector.
93blade
sheppey kent
cl500 2002
These wires are a positive feed to all the sensors around the engine, eg, o2 sensors and turbo waste gate solenoid. The returns from each go to the ecu.
What is first 6 digits of VIN
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Best I can do is the fuse diagrams and layouts for the M278.
A workshop manual including wiring diagrams can be downloaded for £9 95 from
93blade
sheppey kent
cl500 2002
  • #20
Perfect, thankyou..
