mioba
- Feb 19, 2006
- Location
- Nottingham and Köln
- W124/E200, W220/S320CDI, W205/C200, W251/R350CDI 4Matic
look on ebay, always cars being broken
Still looking folks.
I've been in touch with again with bloke at the nearest Mercedes dealer. He tells me that if there are no cut wires then I'll need a complete wiring loom and new port and the vehicle will have to go down to them and it'll cost me anything between £1500 and £3000.
UPDATE TO ABOVE
I’ve had car running sitting in garage for over an hour with no fault messages.
the socket in its standard position is directly above the gap between the brake and accelerator pedals …. sitting on the flat black trim panel hiding the ulgy underside of the dash from being kicked with your toes. It has a 25 x 50mm fold down flap (like most mercs).Just acquired a 2005 E280 CDi W211. It had an issue which I was sure I could fix so I went to plug in the diagnostic machine and couldn’t find the connector port.
Apologies for the confusion there. Yes, I meant messages on the dash cluster not codes. Need to knock those out of the ECU with diagnostic machine but still not found the blooming OBD port. Only the wire coming from the correct fuse which I have now found ends up at the ECU.and now really confused.... how are you getting fault codes from a socket you haven't located ?
going to go back see if I missed a bit - worked it out you mean - instrument cluster "error messages" and or warning lights - it doesn't show faults or codes - hence whey you still want to find the socket
It’s looking like my only option tbh but I just hate being defeated! especially as the car is in brilliant condition with good mileage for it’s age and looks as good as new inside and out apart from a tiny bit of paint missing near a wheel arch and the alloy on said wheel has been scratched which is easy to get fixed locally. If I can’t get it on the diagnostic machine to clear the faults and check for anything else, I don’t want my wife driving it in case she gets stuck somewhere on her own.My honest opinion. If you are that concerned with no resolution in sight, just move it on....
Yes, that’s pretty much it in a nutshell. It definitely doesn’t compute. All that is see in behind that panel is a connector with a bunch of brown wires going in which I have assumed is the CANBUS. Photo attached. I’m at work but will have another look later.the socket in its standard position is directly above the gap between the brake and accelerator pedals …. sitting on the flat black trim panel hiding the ulgy underside of the dash from being kicked with your toes. It has a 25 x 50mm fold down flap (like most mercs).
You must have unscrewed this panel to go look for the wires.... so you are telling us having unscrewed and removed the big 210mm x 400mm trim panel sitting flat above the brake and accelerator pedals - there is no random bunch of wires tucked up out of sight anywhere??? Its doesn't compute (and most likely is there within a range of 18 inches of the original location with the black socket intact)....
Me neither. I could strip the mechanics and body of the thing down to the last nut and bolt and rebuild but auto electrics as complicated as these are beyond me.A very odd post this, just doesnt add up, I would think if there was no odb port there would be some dash errors. But I am no expert in the software/hardware set up side.
My employer uses a very good auto electrician but catching up with him is not easy. If he’s at the yard, I’m likely out. There’s no indy around here that specialises in Mercs. No joy so far on eBay looking for correct model and year OBD with wiring loom. Nothing in the two scrappies either.Have you had an indy look at the car, it come be that some series have it another place, just thinking out loud
Where are you located?
Can you take a photo of the area beside the handbrake release where ir should be?
