OBDII adaptor for W124
Your car has no ODB2 on it, a simple blink code reader should work
M
MercStraight6
1995 W124 E280 estate
Then what is the purpose of the adaptor on eBay?
I know about the blink tester; I've built and used one before. I was just curious if it would be possible to extract more data from the ECU.
It can only extract the same data as a 124 does not have much more on this 38 pin socket, but for all it cost it could be useful for doing some cars up to 2000 that do not have the 16 pin one
M
MercStraight6
I read somewhere that the late 2.8/3.2 M104 engines can give data such as Lambda, coolant temperature, current gear selected (on autos), amount of fuel injected, battery voltage, engine RPM, throttle position etc.
This may well be enough to use a Scangauge to give an instant MPG figure.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Late W124s in America had a proper OBD port. From 1994 the EPA mandated ODB in the USA. AFAIK we never had that requirement in Europe
So American literature (E-Class Owners Bible, etc) may refer to OBD data that's not available on European models
Nick Froome
www.w124.co.uk
M
MercStraight6
Nick Froome
www.w124.co.uk
But they all use the same ECU; so surely with the right connector the same data can be accessed.
kth286
E320 Coupe 95
MercStraight6
Which 124 cars have the 38 pin connectors ??????????????
kbekl
manchester
1998 E300td
i would think post 96 w124's would have the obdI which might be what that advert is on about
The 124 finished in 1995 with the odd ones coming through during 1996
M
MercStraight6
MercStraight6
All cars with the 2.8/3.2 M104 engine with HFM-SFI engine management.
M
MercStraight6
So you have physically seen the 38 pin connector on your car ??????????
I have indeed. I will post a picture if I get chance.
M
MercStraight6
This seems to prove my point:
http://www.ecutools.com/shop/shop.php?action=full&id=9
Converts your standard OBD2 16 pin lead to the 38 pin plug for older Mercedes Benz models (normally before 2001, check your vehicle to ensure)
The 38 pin diagnostic socket is normally found under the bonnet.
This adaptor works with all our universal OBD2 systems in our shop as well as the Mercedes Benz HandHeld Code Readers
M
MercStraight6
  • #17
I expect what you'll find is the square connector by the brake servo. That's not OBD, AFAIK
Nick Froome
www.w124.co.uk
No it isn't. That is the 16 pin diagnostic terminal which is used with a blink tester. Don't Bull**** me.
I'm talking about the 38-pin micro-connector that is on the other bulkhead by the battery, which my W124 does indeed have.
Mine definitely has it; that's one of the main reasons I bought the car. Just have to wait for the adaptor cable to arrive now.
This thread should now be closed; the answer has been established and any further posts will just cause further argument.
kth286
E320 Coupe 95
Look forward to seeing a picture of that 38-pin micro-connector ????????????????????????
CRJ
Are there FCRs that can read from the 16 pin (X11/4) type connector ?
This socket is made for STAR or a compatible reader
