David Pemberton
- Jul 8, 2006
Hello
I wanted an affordable basic diagnostics / fault code reader for my W202 C220 CDI with the 38-pin diagnostic socket, but couldn't find a definitive answer here or elsewhere. I emailed UKOBD Ltd and got a prompt helpful reply: they had a good hunch but couldn't promise. I risked a £100, and their kit works.
More below, and I'll update the thread with a second installment when I've more experience.
Best wishes
David
Here's what UKOBD said in response to my enquiry:
"Thanks for your enquiry, as you are probably aware diesels were not required to be OBD2/EOBD compliant until 2004, however some manufacturers were compliant before this date and according to Autodata your car is, nonetheless we have no specific experience of this vehicle so I cannot give any guarantee that it will work, as such what I would suggest is that you buy the UKOBD interface ( £ 64 95 ) which comes with the Digimoto lite software and the Mercedes to OBD2 converter cable ( £ 23.99 ) and if this works then you can always update the software to the full version 5."
It was such an honest and straightforward answer that I decided to spend a £100 just to find out. (And the kit would work on my other half's Polo).
This is what I ordered:
Mercedes 38-pin to OBDII ISO converter
http://www.ukobd.co.uk/gstore/store/g_viewItem.asp?idProduct=66
UKOBDII ISO Interface with Digimoto Lite software
http://www.ukobd.co.uk/gstore/store/g_viewItem.asp?idProduct=86
USB to Serial Converter (needed for many new laptops without a serial port)
http://www.ukobd.co.uk/gstore/store/g_viewItem.asp?idProduct=10
Total cost £110.93
It arrived by next day post, took just five minutes to unpack and install, and I was up and running reading data from the car.
I'm going to upgrade to the full v5 of Digimoto and will write an update to this thread as I learn my way around the software.
Best wishes
David
Total cost £110.93
