sweeper
- Jan 15, 2008
- Location
- peterborough
- 2014 Viano 2.2 R350cdi
So I have just repaired my Viano, see previous post, engine light and limp mode, now my scanner wouldn't read the fault so I always think it best to take to Mercedes as they have the inside knowledge and should be able to sort things out quicker and usually cheaper, I couldn't get in for two weeks so I had a mobile guy come and check it, his diagnosis was to replace or clean the dpf, now i have some knowledge and experience with engine systems with factory training on diagnostics and I noticed the dpf pressure differential reading were off (reading 0 all the time) cut a long story short I bought a icarsoft MB V3 so i could do some testing myself, following a fault diagnosis chart from work, remove dpf sensor and check pipes are not split or blocked followed by replacing dpf sensor, this cured the problem and I ways able to initiate a dpf regen, everything is fine but i noticed exhaust pressure, boost pressure down stream and atmospheric pressures are all off (around -63b) now I assume the exhaust back pressure sensor is faulty and that the boost pressure downstream is a calculation using this minus the dpf sensor readings, but what about the atmospheric reading, does it have a sensor or is it a calculation taking the, we'll see once I change the exhaust pressure sensor i guess. once upon a time the atmospheric pressure was taken from a sensor in the ecu. I'm a little surprised no fault is showing with the reading being so far out, has anyone else had similar issues? how were they cured? I still have the vehicle booked in but i think i'll cancel it and wait until i've replaced the exhaust pressure sensor in the hope all readings correct themselves.
