Odd speedo problem
cuparboy
1995 C 180
My speedometer has developed a strange problem. Sometimes, after a bit of faster - eg motorway - driving if one stops and then starts going again fairly soon, like stopping at m'way services, the needle will register zero until some mystical and variable speed is reached when it just suddenly starts working again.
This is not too much of a problem usually but the other day it didn't kick back in until I was doing 80 and I didn't think I was going that fast. (No I hadn't looked at the tach :rolleyes:)
Any ideas anyone?
eGuru
Northants
www.artguru.co.uk
C180 S204, S320 CDi
Used to have same problem on my '95 C250D. The needle sticks on the little pin that it rests on. A quick clean by the local garage sorted it. Hope this helps.
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
The cause of your problem is that the paint on the instrument needles and stops becomes tacky after a time and stops them from moving until the potential has built enough to break the hold, it is a common problem on the W202.
To confirm this is the problem, next time it happens give the instrument pod a slap on the top, the needle should pop up. If so this has been discussed often before and you should find the solution if you use the search facility.
Come back if you can't find what you need.
And I am number 3 saying the same thing, just slide some sleeving over the pin or clean as said above
Dec
Ireland.
W202
C220GJS answer is bang on, I had the same problem as yourself and cured it by scraping the paint off the pins at the point where the contact the needles, the problem never occur again.
Dec
