Oh My god
zcars
I have an A Class mercedes for my wife and there is an intermitant starting issue.
When the fault occurs the symptoms are: turn the key and there is nothing, battery is fine there is no noise i.e. solonoid click etc
Then it will right itself later on and will be fine for a day.
I have been told it is the starter motor and that the engine needs to be removed???Cost 1000.
Suerly this can not be right does anyone have any info on a sililar problem, or can confirm the starter change requires a engine removal.
Any news will be good news
Merry Christmas
Zcars
Do the dash lights come on when you turn the key
A210AMG
Hello
I'm sure someone will be around soon, I do remember seeing a picture of an a-class having some 'work' and basically the chassis looked to be removed from the car...
I don't believe it would cost £1000 though even if its a pig of a job though?
type49
Starter motors are very common but removing engine is a bit OTT. The back of the engine needs to be dropped to get to it. MB time is 4 hours. It can be done in 2 but you will still be charged 4. Find a good indie, where are you?? do a search at the top of this page. Before jumping the gun, test the 3-4mm purple wire which is near the battery & dissapears out the floor facing backwards. This is the feed to the starter motor. If this is live when cranking, starter motor needed. If it's not, then it's probably just a relay next to the battery.
Z
zcars
Good Stuff
Thank you young man i will try this as soon as i get the car back.
The chap in the garage reckons the fault has not returned and that he can not read the code unless the fault is live.
I thought that the computer always logged faults past and present?? He may be spinning me a yarn i think
Z
zcars
Good Stuff type 49
thank youand merry christmas
type49
Starter motor doesn't log any fault code. Maybe Santa's elves have fixed it:D
Tel: 020 8863 9233
