I have a 4 years old A Class and want to carry out an oil change, does anyone know where the drain plug is located on the engine sump so that I can drain the oil from below?
Its at the rear of the sump. The sump is alloy and has a flat bottom on my A190. The sump plug has a copper washer as well which you should replace or you may get a slight oil leak otherwise.
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
