Oil change suction pump
Funkyboy
Liverpool
E250 w212 14 plate
I'm going to start servicing my E250 myself and was thinking of changing the oil through a suction pump through the dip stick. I've seen posts saying the dealer's do it that way but not had that confirmed. Has anyone here used one and is there anything to watch out for? I'm aware that there's a lot of oil in the e250 so would probably need a 9ltr pump so you don't have to stop and drain the smaller ones.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
That's the 1 I use. Empty it when suction runs out. It's no big deal.
I’ve a Pela as per above and an electric Lidl one.
Just get the oil up to temp and don’t be tempted to stick the tube too far down the dipstick... once it’s at the bottom stop (good advice...:rolleyes:)
I have a Sealey 6 litre one. Does an excellent job with just enough time to drink a coffee between starting and doing the midpoint empty of the pump (pump auto shuts off when full).
Only car I can't use it on is the 230 so Cole @MBS gets to do that one.
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
Mine's a Draper 10 Ltr, manual or compressor operated. Has a good selection of probe's too.
onefortheroad
uk.
Probably there is no tube ..
Ricardo_e220
Newcastle upon Tyne
R170 SLK230k 1999
I’ve got a sealey 6.5litre one - engine run up to temperature, insert biggest tube (i have 2) which will fit, pump suction pressure go make a cuppa, if needed stop and decant half way and refill...half an hour and oil change and filter done...soo easy and no oil up armpit ;)
ps if buying one go for a large one to suit your car
