jibcl500
- Oct 22, 2005
- Age
- 56
- Location
- Cambridgeshire
- CL500,ML55,SLK280
All
Need some advice on a w203, C270 CDI, I just finished cleaning the air in take, there is a lot of oil contamination on the MAF and pipework from the turbo, I removed all the pipes for cleaning, one small connector was dripping wet with oil, the turbo was wet with oil and the pipe work from the turbo to the MAF was quite wet with oil.
The oil seperator on the engine seemed wet too, has anyone seen this before. Is it the seals on the turbo failing.
jib
jib
