Oil cooler needed in UK?
Isdyl
My 1980 450SL oil cooler has split & apparently will cost over £200 to replace. Do I need an oil cooler in this country? Could I by-pass it?
No you should not bye pass it. They are standard in all contries, both engine and gear box where fitted.
Malcolm
I
Isdyl
Thanks Malcolm.
I will have to start searching for a cheaper one then. The original is unfortunately U/S as both hose connectors sheared off during removal.
mercmonkey
Essex
you could probably get one from Demon tweeks of similar dimensions and fit that. You might need to make a few mods to fit it tho.
