Oil Cooler Seals - recommendations on garages
AB77
Chrysler 300 CRD/2007/OmM642 engine
Chrysler 300 CRD 2007 (123k miles) - Mercedes Om642 engine
I am looking into getting the oil coolers seals replaced. I bought the car a couple of years ago with a known oil leak and although it doesn't seem to lose much oil on the engine dipstick, the under trays are in quite a mess, as is the underside of the engine. I have spent quite a bit of time looking at videos and forums and I am fairly sure it is likely to be the oil cooler seals.
Can anyone in the UK recommend a garage to do the work, please? I live in Hampshire. I understand it is estimated to be about an 8 hour job, so know it will not be cheap, but I am prepared to travel any distance to get the job done well and hopefully at a reasonable price.
I am contacting a couple of reasonably local independent Mercedes garages this week to see what they say but it would be nice to have a recommendation from another Mercedes owner!
Thanks.
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
Had mine done a PCS in Hprndean - great service. I have previouysly used MBS in Southampton for servicing who were also excellent.
mioba
Nottingham and Köln
MBS pops up on here often. Seems to be oil cooler seal season, there has been a few posts on this topic recently.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Another vote for MBS - have used them personally.
Alternative, if you’re at the northern end of the county, you could try Star at Reading, also highly regarded in here.
bembo449
gainsborough , lincolnshire
I'm picking up a 300c this week , I specifically checked to see that it was nice and dry in the oil cooler area , hoping I never have to do the seals while I own it
Craiglxviii
Cambs UK
Thanks.
Check that it isn’t a leaking injector seal dissolving baked on engine crud into your under trays first. That’s what it turned out to be on mine.
A
AB77
Many thanks for the suggestions. I have called MBS and Star but neither will touch a Chrysler 300. Also tried Pro-Tech in Newbury but got the same response. Decent chat with them all and most said it is almost certainly the oil cooler seals as this is a common issue and the Om642 engine, apparently it doesn't usually leak from anywhere else.
Now trying to track down a guy called Gavin Bailey in the Swindon area who apparently has done a lot of work on these engines.
Does anyone have any other recommendations for me to try?
Appreciate the help, thanks.
