Oil Extraction.
Steve Paul Thompson
Liverpool
2010 W204 C350cdi Blue efficiency sport
I,ve used a manual oil extraction pump on my C350 cdi the last 2 oil changes. I dont think I have managed to get all the old oil out but it is so much easier, no laying under the car to remove the under panel and sump plug. I,ve done less than 3000 miles between oil changes and have changed the filter both times. I think I could be leaving a litre of oil I can,t extract in it. I like to think of it as being an oil refresh. Any thoughts? Steve.
Gazwould
C250 CDI
Absolutely .
Sumps are different , best fool proof way is extract then undo the plug and measure what comes out .
On two cars by extraction I'm 100 % happy as the extractor has measurement .
The older I'm further able to suck out a vertical oil cooler below an oil filter housing that would otherwise hold around 300 ml of old oil .
robin.large
CLS C63 AMG 2013
I tend to change oil earlier than recommended interval at around 5k.
I change the filter everytime.
I alternate between sucking out and one change and then sucking out with draining through sump plug on next change.
I'm happy with that.
Sent from my ONEPLUS A5010 using Tapatalk
merc85
HARWICH
E320 cdi
I can't understand why you would work against gravity, But if your happy doing it like that then why change.
EmilysDad
Bury Lancs
ML350
My Smart Roadster gives me no option other than to use an extraction pump ... there is no sump plug if I wanted to drain it at the sump. I had a problem with the car & the sump pan was removed after using my Pela. There was next to SFA in the sump pan when I removed it. ;)
mioba
Nottingham and Köln
Assuming you are extracting the oil when the car is level and the suction hose hits the bottom of the pan I would doubt there is a litre left (that is alot of oil).
Given the oil change is every 3k with a new filter I would not worry about it.
I dont have a Pela but the electric lidl pump, I dont use it for my car, but my ride on mower. Great little device, no spanners, no catch can (direct to oil drum), no hands and knees, no replacing sump nuts, no spills, love the efficiency.
EmilysDad
Bury Lancs
ML350
There was an egg cup full at the most left in my Smart's sump pan ;);)
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
My Sealey 6.5 Liter Vacuum Pump extracts exactly 6.5 Liters of old oil and that's exactly how much fresh oil I put back wich indicates midway between high and low on the dipstick.
I do an oil and filter change every 6 months.
Gazwould
C250 CDI
Same here .
Bearing in mind the above image is currently @6L and still sucking !
Woodleigh
Same here .
Absolutely, and as you can tell I change the oil more often than I wash the car...Lol
Steve Paul Thompson
Liverpool
Thanks mioba. My car was on a slight slope and the weather turned bad half way through so I rushed it a bit. I,m sure I could have got more oil out with a bit of extra time.
dvarley
Loire Valley, France
E 320 T CDI
I use a Sealey pump and always managed to extract 7.5 ltrs. on my E320 cdi. I always remove the oil filter on the top of the engine whilst it is extracting, so that there is no vacuum holding oil in the filter. I think it is a great piece of kit and as I am now 72, I am not good at crawling under the car to remove the tray and oil plug.
Steve Paul Thompson
Liverpool
  • #19
Thanks robinlarge: I will start alternating. I like to change the oil every 3000miles My next will be draining through the sump plug ,so I dont think using an extractor will do any harm.
I've a Pela Vacuum pump but haven't used it since I bought the Lidl 12V one :)
