oil in hydraulics
petehvan
Hi I have an H reg 230TE, I am leaking engine oil into the hydraulics system.
can anyone help.
Regards Pete
brandwooddixon
Wolverhampton
S63 Coupe 2014
You're not very clear in title or description.
Do I take it that you mean that you have self levelling suspension and that you're finding engine oil in it? If so what steps have you made to confirm this?
If not then a clearer description is needed.
Its impossible for this to happen
star
Reading
Smart + others :)
Not so, if its the suspension hydraulics. the self leveling pump, driven by the camshaft has a small seal which fails and engine oil is sucked into the leveling sytem. remove pump and replace seal if its still available seperately.
P
petehvan
Hi This sounds like the route of the problem, Thanks
Pete
P
petehvan
hi Richard
The chassis No is WDB1240832F153672 The parts I think I need are the seal and perhaps the sealing ring to the pump on the self levelling suspention hydraulic pump.
Regards Pete
