Wessel
- Thread Starter
- Thread starter
- #21
They oil may be still as black as normal, but is the level dropping?
My thoughts...... The less you drive it the better. The oil sticks to every internal part of the engine and cooling system. If not cleaned out properly the oil will eventually cause the rubber hoses to deteriorate and go soft, after which they will start to blow.
Whatever type of oil mixes with coolant it always emulsifies and looks like what you have there in varying shades, so the colour is no guide to where its come from.
As others have said, its hard to imagine how falling off the jack could create such a fault.
The driver side wheel was taken off. The driver side brake disk fell about 2 foot on concrete. The jack and the stand was also somewhere underneath. The engine cover below showed that it pushed in a few inches. The coincidence is just too big that the fall had nothing to do with it. I checked it before and the next day after it had oil in the expansion tank. From everything I have read my feeling is that the oil cooler or transmission cooler cracked with the fall causing the mixing of water and oil.
