futsysmids
- Apr 21, 2007
On my mercedes C180 1997 auto - 87k fsh, I have an oil leak.
I get spotting on the driveway.
I have had the gearbox looked at under warranty and have been told that the leak is not coming from there - plus the fact that apparently the gearbox is a sealed unit.
They informed me that I should get the engine completely steam cleaned and take it a 500 mile run to find out where the leak is coming from.
I have a small crack and hole in my oil filler cap - could it be coming from there? The breather pipe from the engine also needs replacing as the old one seems too hard - could that be the problem?
Or could it be that in jan 2007 - prior to owning the car, the previous owner had the waterpump replaced - not a cheap job - i would assume that you would not replace it unless it had failed.
Could it be that the headgasket got wet, thus causing the head to "rust" a little - thus causing a gap caused by rust?
Help???
Help???
