Old Bentigger
Old Bentigger
Oxfordshire
500SL starting procedure?
As a fairly recent owner of a 1985 500 SL I have been accumulating a (fairly short) list of queries . This one concerns starting the engine when it is warm.By which I mean when it has been running and has stopped for between 30 and 90 minutes.It otherwise behaves impeccably .
The car starts first turn when cold and also when hot but when warm it takes a few cranks, needs the accelerator (or should I be depressing this fully?) , runs lumpily for a few seconds then settles down. Not a real problem in practice but I am puzzled why this different behaviour when warm.
Regards to all :-?
OB
Unleashed
Norwich, Norfolk
www.flooby.co.uk
I'm not entirely sure on your car, but on my 190 before turning the key I push my foot flat to the floor on the accelerator pedal for just a second, then ease off and start. Apparently it's called priming the choke. If I don't do that it starts very lumpy and not well.
stwat
Sheffield
1989 300SE
Im asuming the 500sl is fuel injected, so priming the choke does'nt apply, as it does'nt have one. But im also having the same hot start probs as you OB. It seems to be an over fueling problem. Ive read elsware that it could be the coolent temp censor that is at fault, giveing a false "cold" reading to the comp, which in turn then sparks the "cold start boost valve" into action.
The way to check this is to unclip the connection to the boost valve when hot and see if the problem persists. I havent got round to doing this yet but im going to give it a go this weekend when i service my car.
Stu
pascal
near Dublin
sl320/1999/3.2
Please put your query in the title box; not yor name
Pascal
O
Old Bentigger
Oxfordshire
500 SL starting procedure
Yup, I think that is the correct diagnosis , stwat; since I like it to start first time and avoid the ignorant/critical comments from bystanders (with friends like that ....???) I will sort it!
Thanks, Robin aka OB
wingspan
My 500SL starts like magic but lately having started after a while it starts overrunning at around 1500 rpm. Eventually this settles down but could it be the cold start boost valve resposible for this?
