davidsl500
- Oct 24, 2004
- Age
- 122
- Location
- Home : Derbyshire at the moment !
- R172 250CDI Gone..!, R129 SL500 Gone...
So almost to the day 12 months on the SL starts playing up again.
Symptoms : Starts immediately when cold, drives okay then as it gets up to temperature it starts to miss, gets worse and dies. Wont restart until its left for a good 30 mins then off we go again.......Does the same thing if you start it and just let it idle - warms up then misses and coughs to a halt.
I went straight to the cure this time after last years Sherlock Holmes adventure... Both Distributor Caps wet as wet can be and the terminal posts in a bad state. Beats me how there is no indication of the problem earlier - just look at the moisture and build up of crud on the terminals !
The distributor cap seals were changed last year so I am suprised the problem has returned.
All cleaned up with Servisol and now perfect again. Weird its always October when it does it - change in the weather I suppose...
