Judwin
- Sep 23, 2021
- C180/2013/M274
Hi, First real problem with me-merc. Not sure if I should be posting in DIY or Engine, so mods please move if I've got it wrong.
2013 W204 C180 OM274 (so 1.6L petrol turbo)
Noticed a very occasional slight hesitation on Saturday, heading from St Dizier to Eindhoven. No EML. However Sunday afternoon traveling from Eindhoven back to Brussels the hesitation turned into more of an occasional miss-fire, and the EML came on - sometimes solid on, sometimes flashing. There was a whiff of petrol when we got to Brussels. Once we'd done Brussels (about 2 hours) the car was reluctant to start. On the long trip home from Brussels to Somerset (via Koksijde & the chunnel) the missfire was there all the way, and the smell of fuel when stopping very marked.
It's now very slow to start, and at tickover it's very lumpy, like it's running on 3 (or even 2). It seems Ok-ish (tolerable) on light throttle. On heavy throttle it's an obvious missfire, and it struggles to maintain speed up hills. EML is now on all the time with just the occasional flashing spell. And it smells of fuel.
My initial thought diagnosis was either a fouled/failing/failed spark plug, or a failing/failed ignition coil, but without a code reader I can't tell if that really is the issue. Doubt it's fuel injector since it does smell of fuel. So...questions
1) Is it possible to flash out 'blink codes' on the dashboard somehow?
2) Any recommendations for a suitable code reader and software for this engine?
3) Any common failures that match this fault description?
Cheers
Judwin
Cheers
Judwin
