- Aug 4, 2016
- Location
- Sunny Essex
- W211/E320cdi/2009 and CLK200k 2009
Due to the sunshine , I had done this job 3-4 years ago so I thought I would remove the actuator again and clean it out .
Turbo shield removed , 3 bolts .
Then the split ring on the actuator arm popped off very carefully you could tie some cotton on it , but I only did this when I refitted it .
Three bolts on the back of the actuator which released it , then I pulled the end of the pcv tube out of the batwing to get more space to free the actuator electrical plug.
Actuator removed , I popped the clips off , spray cleaned the inside with electrical contact cleaner , then added a tiny amount of high temp grease to the worm gear .
Back to together and all refitted with no issues .
